truckfarmer49
My parts diagram and shop manual seem to be incomplete.
It appears that #14 outside neoprene u-seal (see image) - which I scraped off - was actually one unit with an outer metal casing. The casing/u-seal unit looks like it was hammer fitted into the greater steering gearbox housing.
You can see this metal outer seal collar in the second photo down, without its rubber inside but still attached to the housing. How should I remove this outer casing from the steering gear housing?
