This is the first time the 4020 has been inside a shed in 15 years and she needs a Little tlc before spring . Going to replace the center steering arm both inner tie rod ends and reseal the pto output shaft which has been leaking for as long as I can remember then reseal the breakaway couplers and replace one barrel on them that?s cracked around the ball and one of the scvs under the hood is leaking also going to a do little paint touch up and get the other Firestone put on the back . Scraped snow for my friend at his new horse tonight and the hydraulic cylinder worked flawlessly and no leaks which I was surprised considering the things it?s gone through
I guess a picture of a 3020 got in there somehow adjusted the valves checked the timing and it needs some scv work as well and some 3 point hitch work
