roy prins
Up date on a loader I worked on -- The bucket would drop ok for a bit then slow for the rest of the stroke-- back up it went the same -- thought I better check for some bad hyd. hoses -- took all for hoses off and they looked good-- but then I saw the problem- some one needed swivels to attached the hoses to the cyl.s and used .031 orfices -- what??? drilled them out and all is well -- no money spent and the stupid thing works much better -- how silly can someone be? alls well that ends well as they say -- Roy from northwest Iowa
Someone must have wanted the cycle time to be a bit longer. I've used those swivels on my logsplitter log hoist. The stock orifice was to slow, so I kept drilling bigger until I liked it
Actually it is a safety feature. If you ever ride on an elevator that is hydraulic, they are in the lines. There is a high flow and a low flow so the car doesn't bump or surge as it goes up and down. If you have a crummy operator and they open the valve full tilt the loader can crash down. Another thing you see regulated like that is the small whistle on a caboose. It has 1/2 inch pipe but on the inside is a brass washer with a 1/8 hole. That whistle you can blow with your breath but the brake lines are 80 pounds plus. That washer only let's through so much air. Some physics is neat!
To each his own for the way of doing things. I feel more efficient loading up a trailer load of log pieces to split and pulling the splitter up behind the trailer. Roll pieces on to splitter, quicker than lifting one at a time.
