What is this tractor??
Jaydipper
New User
I apologize for the previous post I forgot to add the pictures. This is the tractor that I acquired on a trade. All I know is it says International Harvester 340 utility. Trying to find out what year and model it is.
If it says 340U then you know the model it is. It is a 340U. As for year look on the left under research and info then serial numbers and see where your serial number falls into palce
You have pictures of casting numbers and the date codes. Somewhere on tractor is a small plate with the serial number and other info.. Different models will have that plate in different locations. You have a tractor that has been repainted. The plate may have been plated over, which will make it harder to find.
