Little 3.5 inch bore cylinder just isn?t up to scraper duty at least the price was right I think I?m going to upgrade to a 5 inch so I can get a 2 inch rod . Caught something buried and ripped the nut right off the rod that holds the piston . Rethreded the rod cut down a regular inch nut to be the right thickness screwed on tight with green loctite and then welded the nut on .
Had to get out the fiat to dig the tire chains out of the snow bank so I can chain up the 4020 this weekend when I go back down to work on the new baler . Also Found a smaller scraper with category 2 lift arm spacing between pins to fit the 3020
