Worked on a 4030 jd with jdb pump.elastomer ring disentigrated installed seal kit no glass ball in return.tractor now runs fine for a minute or so then sluggish above 1500 rpm. Put clear hose in return see about 4 bubbles every 15 seconds.replaced lift pump no help.transfer pump pressure about 30 psi but guage needle has rapid fluctuation. No suction at transfer pump.pulled pump back off going to tear down again.plenty of fuel delivered to injector pump.going to look for vent wire.any ideas appreciated.thanks.oh yes set 5 gallon can on floor with electric pump from an old gm Tbi car run through inline filter to injector pump runs fine at all speeds all the time.thanks
