Another project
SVcummins
To add to the list of things to do before spring . Need to replace the center steering arm and both inner tie rod ends reseal both breakaway couplers and reseal the pto housing on the 4020 . Also need rmake new tabs to hold the steering console to the tractor . Also hope to get a set of duals made by spring . This photo is when it still had 15.5.38
With 18.4.38 on 14 inch rims
may I make a suggestion to you SV.....when replacing your parts on your tie-rods where bolts no. 11 and 15 are, put another set of bolts through the tie-rod....iv seen single bolts sheer off and then you cant steer the tractor
