BHpony
My super c gets hydraulic oil in crankcase so need to rebuild pump. Anyone done this & how to tell which pump I have. Looks like there are 2 listed on this site. thanks for any info.
There is not much to rebuild - new gasket and most important a new seal. If the seal has worn a groove into the shaft you may be able to fix it with a speedy sleeve. If you can't do that then you probably will never get it to stop leaking oil. Had that problem on my 100 - finally gave up and bought a new one.
all you need is a seal. Carefully take it apart. Inside you will find a O'ring and seal. Carefully remove,take the old seal to NAPA,they can match it up and supply new.Reassemble. It helps increase the life of the repair if you emery cloth/clean the shaft before reassembly. Coat the seals with a bit of hydralic oil during reassembly.Not a hard job at all.
