Tractor Talk Discussion Forum
Re: Let’s see your plowing jobs
Jon f mn
12-08-2018 18:09:16
Got a little plowing done this fall.
third party image
third party image
Did have a little trouble with water and wet tho.
third party image
third party image
Didn't get done this fall because it froze. Next spring is going to be tough around here because spring plowing is bad news.
SVcummins
12-08-2018 21:32:36
 Re: Let’s see your plowing jobs in reply to Jon f mn, 12-08-2018 18:09:16
Jon is that an Oliver plow ?
Jon f mn
12-08-2018 21:57:11
 Re: Let’s see your plowing jobs in reply to SVcummins, 12-08-2018 21:32:36
Yes, belongs to my friend.
SVcummins
12-08-2018 22:09:36
 Re: Let’s see your plowing jobs in reply to Jon f mn, 12-08-2018 21:57:11
I’ll heve to find an Oliver plow I guess and see how it does here . I have pulled an melroe plow with Oliver bottoms and it did a nice job
jeffcat
12-08-2018 19:24:11
That mess looks like a Barge cannal. The water was actually running was it not?
Jon f mn
12-08-2018 19:33:14
 Re: Let’s see your plowing jobs in reply to jeffcat, 12-08-2018 19:24:11
In the one pic yes.
SVcummins
12-08-2018 18:24:53
Looks pretty good jon . It was so dry and hard here plow shares would only last 20 acres before they were worn out . I got froze out to got about 30 more acres to plow come spring to finish the one field . If you Want I can bortor you the lely it’ll Mellow that spring plowing right out
Jon f mn
12-08-2018 18:54:51
 Re: Let’s see your plowing jobs in reply to SVcummins, 12-08-2018 18:24:53
I would be surprised if that worked here. I've seen a couple around, but only in the peat ground.
SVcummins
12-08-2018 19:50:57
 Re: Let’s see your plowing jobs in reply to Jon f mn, 12-08-2018 18:54:51
I run it over our heavy clay ground and it really works the ground down
