White 2-75 Tractor
RCP
Location
Grove City Pa
I have been interested in White 2-75 tractors, two I have found have transmission issues and one reportedly has the brakes locked up. Are these tractors prone to transmission issues?
Thanks
Rich
One guy I do repairs for has one with one shift fork that?s bad. None to be had as this is a week point. Going to tear down sometime this winter and see what we can do. Other then that they are a decent tractor. As for the brakes being locked up I?d make sure that the rod coming out of the axle housing returns when the pedal is up. Maybe the break discs are wore enough that the balls are getting stuck and not returning when the pedal is up. You have to pull axle housing to change the breaks so it?s a job!
A lot of the older Iseki built tractors are near impossible to find parts for other than a salvage yard.I have a small Bolens built by Iseki no parts sources,I'll just run it
until something major beaks and park it until I find a parts tractor.Bought it cheap so that'll work.
