Company Logo Shop Now
TractorLinks.com
Tractor Talk Discussion Forum
Almost Lost Everything
fbh44
12-06-2018 23:09:35
Just went out to the barn, it is 1:00 am here, to check on the Farmall, almost all ready for the Christmas parades. Opened the barn door, the smell of gasoline overpowering. Luckily did not turn on any lights yet or spark anything. . Mice had chewed the rubber gas lines, in many places, had pools of gas everywhere. Wife and I rolled the tractor out the barn door and downhill a ways. Feel very lucky. Maybe I'm stupid for using rubber gas lines. Could have lost barn, several tractors, all tools, compressors, etc etc etc. If you have rubber gas lines, you might check them, all the way from tank to carb. Best of luck. Happy Merry Christmas.
Traditional Farmer
12-08-2018 06:05:30
 Re: Almost Lost Everything in reply to fbh44, 12-06-2018 23:09:35
Think you need to address the rodent problem I have had mice and rats chew a lot of things but never a fuel line.Plus its a good idea to cut the gas off on gas tractor anyway,I've seen carbs start to leak and run gas in the air cleaner and all over. Near me years ago a guy I knew had someone try to steal his tractor they were going to drive it away only got as far as the gas in the carb would go as he had turned the gas off.
The tractor vet
12-07-2018 10:18:31
NOPE will not install a rubber fuel line on a tractor . Had one guy want me to come put a rubber line on his 560 gas many years back along with a inline filter . I told him no i would not do that but i would build him a steel line and clean his tank out and install a new sediment bowl . He did not want that and was in a hurry to get the PICKER mounted . Well he found someone else to do as he wanted . At some point in time while picking some fodder caught fire and the fuel line started to burn and the plastic fuel filter melted and he was not able top put out the fire and the fire dept was only min. away , well buy the time they got there she was really cooking the field was on fire then the tires blew then the fuel tank let go all as the fire dept stood back as there first question was GAD OR DIESEL . and when the word Gas was said all they said was stand back . Then once it went BOOM then they worked on getting the fire out.
Steve@Advance
12-07-2018 08:35:44
Close call for sure!
That's one reason I don't like rubber fuel lines.
Not only do rodents like to chew them, old age and ethanol rot them, hose clamps work loose, and if there were ever a small fire, it would quickly escalate once the hose gave up.
Most of the old tractors use 5/16 steel line from the factory. Same as pre flared brake lines. The steel used in those lines is an alloy that makes them exceptionally easy to hand bend, even without a bender it can be carefully shaped without kinking.
rustyfarmall
12-07-2018 07:27:50
Yes. It is kind of pricey, but it still cheaper than repairing the damage done by those nasty little critters. We used to have problems with mice getting into our house. I bought some outdoor bait stations, and filled them with Havoc. Haven't seen a mouse inside the house since.
ChasK
12-07-2018 07:20:14
Am I the only one wondering why he checks on his tractors during the night??
fbh44
12-07-2018 07:28:12
 Re: Almost Lost Everything in reply to ChasK, 12-07-2018 07:20:14
ChasK _ I had to laugh at that.... I don't know why, I'm getting her all ready for the Christmas parades, and something said go check on the H. So I did.
BarryfromIA
12-07-2018 06:41:21
Cats and cat food are cheaper than rodent problems and there cost. Cats can be funny at times also.
DoubleR
12-07-2018 06:29:32
A guy at my church was draining the gas out of his N Ford in his garage last week. He stepped out for a minute while it drained and something ignited it, pretty much lost everything in the garage.
MkinON
12-07-2018 06:10:57
Had mice chewing on the wiring of an Odyssey van that mostly sits. After it was Krown rust sprayed, all the chewing stopped. I've seen the same result on another truck that doesn't get used much.
rustyfarmall
12-07-2018 06:07:22
Go to your local farm store and buy a bag or two of "Havoc". Be nice to those little critters and feed them.
Jim in rush co
12-07-2018 06:53:04
 Re: Almost Lost Everything in reply to rustyfarmall, 12-07-2018 06:07:22
rustyfarmall, that Havoc is the best I've ever used but kind of salty. The last pail I got was over $50.00 and need to pick up another at Co-op only about 3 packets left.
blackhole49
12-07-2018 05:12:58
I turn the gas off at the tank on all of mine. When I smell gas it usually because something was left on. 1/2 of mine leak without the mice. Your barn must be awfully airtight to worry about lights setting off a leakly gas line.
showcrop
12-07-2018 04:59:47
Sounds like time to put in a stainless steel covered fuel line.
OregonAaron
12-07-2018 04:44:48
I think the poison he is talking about is called ranick. I use the same stuff, works good. We have several rodents to contend with out here- packrats, sage rats, regular mice, and kangaroo rats. It's a never ending battle. Just keep your fuel shut off at the tank and you shouldn't have to worry about a major disaster.
pinball
12-07-2018 04:31:18
orchelns sells a mice poison for about 12 bucks. comes in a package like a block. you can break it off and put them under benchs, cabinets, etc where dogs or cats cant get to them. starting using it 3years ago. only mice I find are dead ones. i live in the country and I have a 35x60 unheated barn that some times in the winter I may not go in there for a week or so. decon also works but more expensive. glad you found it. that would have been terrible for sure.
Mike M
12-07-2018 04:29:04
That may be one of the reasons these older tractors had hard lines on them originally ? That and cows pulling/chewing on them.
Blue_Tractor_Man
12-07-2018 04:21:08
We have a couple of indoor/outdoor cats, and never have any mouse trouble. I guess they are highly effective.
kcm.MN
12-07-2018 03:05:23
Like many other animals, mice like to follow their noses. Everywhere a mouse goes, it leaves a trail of urine, like the fabled trail of breadcrumbs. Unfortunately, once their scent becomes dried in place, even washing will often leave enough trail to attract other mice to investigate.
I would try first washing the machinery with soap & water. Then try spraying different things to mask any remaining odor trail, such as ammonia or maybe even bear (pepper) spray.
We had never seen ANY sign of rats here until just the one time a few years ago, when one got locked in an outbuilding over winter. I had a 5-gal plastic gas can full, with the spout sticking up. The spout was sealed, but I'm sure gas could be smelled. Still, the rat (we presume) got awful hungry that winter and.....well, see for yourself!
third party image
Ivan in Mich
12-07-2018 04:53:16
 Re: Almost Lost Everything in reply to kcm.MN, 12-07-2018 03:05:23
I have the older style spouts and the red squirrels chewed a hole in one of mine out at the tip
Traditional Farmer
12-07-2018 03:54:58
I have a plastic water line coming down off the mountain on my place from a spring,I use it to fill water tanks.Bears will chew on the end of the pipe
Stephen Newell
12-07-2018 02:00:45
You might start cutting off the fuel at the tank when you are done using them. Rubber lines are good in that they flex with the movement of the tractor.
2x4
12-06-2018 23:33:23
unbelievable what those little monsters can do. Got one that's found a way into my Subaru & chewing the devil out of everything. Mousetraps but it won't take cheese, peanut butter, meat or seeds. Leaves for a while, then comes back when I least suspect it. Park in different places, finds the car. Can't find where its getting in at. Its an evil genius as far as I can tell. Wouldn't surprise me if it torched the car some night.
SVcummins
12-06-2018 23:51:51
 Re: Almost Lost Everything in reply to 2x4, 12-06-2018 23:33:23
Hopefully if he does torch the car he gets burned up to
oldsarge
12-07-2018 06:22:01
 Re: Almost Lost Everything in reply to SVcummins, 12-06-2018 23:51:51
Yeah,and hopefully your insurance company never reads this,...........shh
