Company Logo Shop Now
TractorLinks.com
Tractor Talk Discussion Forum
IHC 1 1/2-2 1/2 hp engine
Rick Anderson
12-06-2018 10:53:07
Won't keep running. Any ideas? Is the screw just a fuel shut off or is it for adj. fuel flow ?
third party image
Dkanten
12-10-2018 07:43:54
 Re: IHC 1 1/2-2 1/2 hp engine in reply to Rick Anderson, 12-06-2018 10:53:07
The check ball is in the screen. It must be in the tank for it to run.
Rick Anderson
12-07-2018 10:25:11
Thanks guys. Ill give it a go
rustred
12-06-2018 11:37:48
Fuel needle valve is to be 1/2 turn open. It has a mark on it. There is a check valve in the line in the tank. If it dont have it thatís your problem. When starting press down on choke and they start on 2nd or 3rd. Crank.
flying belgian
12-06-2018 13:51:00
 Re: IHC 1 1/2-2 1/2 hp engine in reply to rustred, 12-06-2018 11:37:48
I doubt it is the check ball. When that ball sticks (and they always do) it will not run at all.
rustred
12-06-2018 19:54:42
 Re: IHC 1 1/2-2 1/2 hp engine in reply to flying belgian, 12-06-2018 13:51:00
that is correct it wont run with stuck ball because it is preventing gas from being sucked into carb. the ball sticks down. in his situation he says it runs but stops. that means the ball check valve is not working or not even installed. it has to be used. i have a pile of these engines and has worked with them for 50 years. every one takes needle valve 1/2 turn open. to stop engine close needle valve.
Rick Anderson
12-06-2018 11:13:23
Trying to upload a video of it running but not having much success
Rick Anderson
12-06-2018 11:12:03
How many turns open should it be?
neverfear
12-06-2018 11:22:45
 Re: IHC 1 1/2-2 1/2 hp engine in reply to Rick Anderson, 12-06-2018 11:12:03
I would start with about a turn out. Then watch the exhaust, if it's black and smoky,lean it out. If it misfires and starts coasting down richen it up. You kind of need to find a good balance where it runs clean. It looks like you are trying to feed it from a temporary tank? I don't recall if those engines need a check valve in the fuel line or not but it's a possibility.
neverfear
12-06-2018 11:06:45
It is your fuel mixture. Out is rich, in is lean.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
