John Deere and farmhand f11
Friend used to have one on a 3020, worked out good. Other than crawling on from the back and fighting the batteries in and out, was ok. Was going to mount the pto pump on the front with a chain and sprockets but never got in done.
It will be just like it was with the loader on the 4020. Only the tractor would be smaller.How about buying an older/cheaper (M farmall,etc) to put the loader on?Back in the 'old days' I loaded A LOT of stuff with an M/F11.
If you only use it occationally to lift things,and not every day to feed,an older,cheap tractor would be the answer.An M would be a perfect tractor. I have 4. LOL!
I wish you weren?t so far away I?d try talking you out of one . I don?t need a loader very often and the farmhand comes off with 6 bolts so I think I?m going to make an a frame out of some poles so I can take it off and put it on
Power steering is nice,but not necessary. I've never had powersteering on M and loader in my life.You learn how to steer.Rear tires filled and one or two sets of wts will hold down about anything the loader can lift.
Wont you have to remove the fenders and slide the wheels out to make it fit between the wheels?Seems like a lot of extra work.
Will have to move the wheels out . The fenders will fit with the brackets that?s how I have it setup on the 4020 .
(quoted from post at 08:01:04 12/06/18) Power steering is nice,but not necessary. I've never had powersteering on M and loader in my life.You learn how to steer.Rear tires filled and one or two sets of wts will hold down about anything the loader can lift.
20 years ago I said the same thing.
How about this?
https://www.bigiron.com/Lots/1952JohnDeere602WDTractorwFarmhandLoader
Wouldn?t mind having that whole thing. Right now
I?m looking at a Massey Ferguson backhoe with a
cracked block . I have a friend who?s dad is pretty
handy at fixing cracked blocks
