COLD COLD rainy day for an auction
not much small stuff.
-Case I.H. #7140 Magnum diesel tractor w/cab, heat & air, 14.L x 16 front & 20.8 x 38R tires w/20.8 x 38 axle duals,
3 hyd. outlets & 12 front weights; $15000 AND HAD A TOUGH TIME GETTING THAT LOOKED GOOD AND HAD OK REAR TIRES/DUALS.
-International 1086 diesel w/18.4 x 36 rear tires, wide front, rear wheel weights, 2 rear outlets & lots of hrs.!; RAN UP TO$7000 BUT THEN THEY ANNOUNCED IT HAD A BAD TA AND RESTARTED THE BIDDING STILL BROUGHT $4500. TIRES WERE so/so. SEEMED TO BE OK SO/SO MECHANICAL SHAPE. CAB WAS STRAIGHT BUT SHOT INSIDE
-International hydro 100 diesel, cab, 18.4 x 38 rear tires & wheels, 1 new rear tire, 2 hyd. outlets w/International loader; ONE NEW, (STILL HAD VENT DINGGLES ON IT) REAR FIRESTONE. OTHER TIRE WAS SHOT. FACTORY IH CAB WAS COMPLETE BUT A LITTLE BEAT UP. SEEMED TO RUN OK. HAD BALE SPEAR NO BUCKET. BROUGHT $5000
-International 986 diesel w/cab, 18.4 x 34 rear tires & wheels, 3 hyd. outlets, needs attention; OK MECHANICAL SHAPE. FACTORY CAB WAS TOTOALY TRASHED. REAR TIRES WERE SHOT. BROUGHT $4500
-Long diesel tractor w/blown engine, parts tractor; I WAS SURPRISED THEY GOT $350 FOR IT. NO IDEA WHAT WAS WRONG WITH MOTOR.NO OIL ON DIPSTICK
-Bob Cat #753 Skid Steer w/Kubota diesel engine,rough; SAID ROUGH BUT LOOKED BETTER THAN ALOT I'VE SEEN, KUBOTA ENG RAN AND STARTED GOOD. OK TIRES. BROUGHT $4500
-Bob Cat #709 backhoe w/14? bucket; LOOKED ALMOST NEW. TRIED HARD TO GET $2500 COULD HAVE MADE A BUCK ON THATONE.
SO/SO HAY WAGONS AND GRAVITY BOXES BROUGH $150 TO 250
New Holland #H7230 10? Discbine w/540 P.T.O.; BROUGHT ABOUT $6000
New Holland BR 740A round baler (Silage special w/xtra sweep) net wrap, oiler & 1000 & 540 P.T.O. gear boxes; BID WAS AT $4000 OWNER SAID NO. WANTED $10,000, SETTLED FOR $9000 LOOKED GOOD BUT SIDE PANNELS WERE BEAT UP.
2 EZ Haul 8 & 9 bale round bale movers BROUGHT AROUND $4500 EACH. LOOKED OK.
-Oliver later model semimounted 5-16 spring reset plow with so/so points brought $250
2 66 or 86 IH wide front axles brought around $100 each.
i think the highest bidder number i heard was around #74
