Finished frost seeding
SVcummins
Or dormant seeding alfalfa this morning at 1030 . This custom job is done . Now I have a coupe small fields of mine own and then I can sit in front of the fire and thaw out maybe buy spring
Thanks David . I?m going to use the hoe drill on my fields . Two reason to set the seed under the snow and also trying to do one field with tillage at all . The openers on that lz1010 have enough pressure they will cut through the sod
Someone needs to invent 12v heated socks, gloves, jackets, and pants. Or a complete outfit all in one, head to toe heated.
Sometimes arctic carharts and arctic boots isn't enough.
(quoted from post at 05:32:01 12/03/18) Someone needs to invent 12v heated socks, gloves, jackets, and pants. Or a complete outfit all in one, head to toe heated.
George,
Milwaukee has had 12v heated jackets for a couple years. They just released heated gloves, but they're dearly priced at 160 a pair, and each glove has a 2.4v battery on them.. A hunting buddy has battery powered heated socks, but I haven't heard him say anything good or bad about them.
I would like to have of those . I?m going to see how the hoe drill does without doing anything tillage
I had two pair of insulated pants 3 shirts a Carhart hoodie a goose down coat and my oilskin coat two pair of gloves and if wasn?t quite enough
I hope buy next year to have a cab on one tractor and at least have the heat houser on this one
