farmall 300 hydra touch line leaking
i have a farmall 300 with hydra touch hydraulic system my steel line is bad at the valve bank i was wondering if there is a block i can buy to replace the steel lines with hose as i have bought the block for my pump from steiners but they do not have the end for the valve bank
First place you need to find is a good old hydraulic hose repair shop.
They should be able to fix you up. I have a steel line on my 300U
power steering unit. No leaks kinks and all.
Is it possible to remove the tube, cut off the block, and tap it for a hose fitting/thread?
