Thickness of gasket paper?
Hi,
What thickness gasket should I use? On my International 383 I needed to remove the hydraulic assembly off the gearbox. I will be getting some gasket paper tomorrow but roughly what thickness do I need? Main options are 1.6mm and .8mm and 4mm.
Thanks!
Joshua
get the same thickness as the old one you are replacing. You are going to need to remove the part and need a new gasket so remove the part now then you can get the same thickness
You could also buy a square of each thickness. That way you have some in stock. Always replace with the same. Have definitely been there!!
Gene ..... wouldn't the thickness on a used/compressed gasket be at least slightly thinner than a brand new gasket off the parts shelf?
Pep Boys has a good selection in packs with various thickness and material. I used to keep a few packs around. Something like an oil pump cover thickness matters .
