Allis 180 3 point hyd question
bankshotone
New User
I'm trying to figure this tractor out, what is the needle valve adjustment for?
I'm assuming it have something to do with the hitch? The hitch doesn't always want to lower when the tractor is running. Would there be anything else I need to look at for this problem?
Thanks
Do you have something on the hitch? If not that is normal. Also make sure if you have a lever marked max depth at one end it is in that position
I have something similar to that on my Kubota that is used to regulate the amount of time it takes for an attachment to fall. Could it be something like that?
