Yep. A lot of people would prefer to curse the darkness because lighting a candle would shed light on the fact that we haven't been very good stewards of our environment. It's easier to make jokes than to recognize that we have been going in the wrong direction for a long time because it's cheaper to take without putting back.(quoted from post at 16:27:53 11/23/18) Climate change, such as colder than normal temps because of abnormal weather patterns. Also hotter than normal temps because of abnormal weather patterns. Pretty easy to figure out, really.
(quoted from post at 12:24:05 11/23/18) Northvale ..... surely you are aware of the fact that by definition, "weather" (like a cold snap in your area) and "climate" are totally different things. I remember my teacher teaching that sixty years ago so I'm sure you heard the same thing.
Al Gore got ye hook line and sinker eh :roll:(quoted from post at 08:27:53 11/23/18) Climate change, such as colder than normal temps because of abnormal weather patterns. Also hotter than normal temps because of abnormal weather patterns. Pretty easy to figure out, really.
(quoted from post at 00:35:45 11/24/18)(quoted from post at 12:24:05 11/23/18) Northvale ..... surely you are aware of the fact that by definition, "weather" (like a cold snap in your area) and "climate" are totally different things. I remember my teacher teaching that sixty years ago so I'm sure you heard the same thing.
+1. I thought that was common knowledge, but maybe not. El Presidente doesn't know it either, apparently, but then there's a lot of stuff he doesn't know.
Here in Minnesota you'd have to be either under 25 or deaf, dumb, and blind not to see that almost without exception, the winters here are clearly and obviously dramatically warmer than they used to be going back 25 to 30 years and back to the begining of records. Here in the Midwest, this has happened each and every year.
Also, it is clear and obvious that the current summer rainfall patterns are completely different again than they were 25 years ago and going back to the beginning of recorded history here.
You might as well deny that oil and water don't mix.
Grouse
Any time it's hot somewhere, it is attributed to climate change, but when it's cold, it's just weather.(quoted from post at 15:42:10 11/23/18) So, when there is unusually cold temps, does the global warming talk just ignore the event. I know when it is usually hot , or dry, or wet, or stormy, or wild fires, it is non stop commentary on warming and climate change. And, the obvious thing about climate change discussion is everything associated with it has BAD consequences. Everything. No exceptions. So, when it gets really cold, we must be chock full of benefits, right? Must be so. So, are we going to hear about any?
