I bought a JD 5210 collarshift this past spring. I put in a block heater, and changed the engine oil and fuel filter, and did some other electrical work, but just replaced the hydraulic filter (didn't see any sign of water in the fluid).
This morning it was 0F outside, and below 20F in the barn. The 5210 started right up after warming with the block heater, and the 3 point lift and power steering worked, but I couldn't get it out of park. I assume there is water someplace that froze. It should get above freezing this weekend.
I am hoping that getting it good and warmed up and changing the hydraulic fluid (10 gallons) will fix it.
Thoughts?
Thoughts?
