Recently acquired tractor. Previous owner converted to alternator. Once I replaced the solenoid, so itwould crank. No spark. Shine up points, no spark, test for power to coil good. test light on distributor side of coil, no blinky blinky while cranking. remove wires from coil test resistance with multi-meter, 0 resistance from input terminal to output terminal. Not shorted, but no resistance. Coil is bad-correct? So coil has been painted over, I can see no marking as to 6v or 12v. Wire to input terminal comes from a resistor. Is my coil 6v or 12v? And what do I replace it with? Thanks. gobble
