4020 power shift worn linkage
320Farmer
New User
Have a 66' 4020 power shift. Want to repair worn linkage in the
transmission control valve ( down on the right side of the transmission.) Tried to take the valve cover off, but it don't seem to want to come off. Do I have to take the whole control valve off to fix this ?
Thanks
If your referring to item #10, then yes you need to take the complete valve off the tractor and work on it on a bench.
Drain the oil prior to removing the valve, you wont regret it.
Also, since the oil is drained check the sump screen for debris.
(reply to post at 06:07:14 11/20/18)
Thanks Hay maker.
Yes, that is what I was talking about. I have the bolts out of that piece & it is loose, but it won't come off. I was afraid the whole valve asy. had to come off. Not looking forward to removing that.
Do you know if I have to watch for balls or springs or anything
that might fall out when I take it off ?
Nothing will fall out loose when you remove the complete body, It is not as bad as it looks..
to haymaker 2
I have been reading some back articles and found one you wrote on a rebuild you did on a power shift tractor you had, and were having pressure problems on it. did you ever find out what the problem was? just wondering how it turned out. I also find myself using the inching pedal as a clutch pedal all the time even when shifting.
