I have an 09 Ford Fusion with the 3.0L V6. Almost 180k miles. The oil pressure light turns on at low idle <700 RPM and warm engine ~30 minutes of driving. It will turn off if I give it just a little accelerator to get the RPMs up. What should be my next steps? Oil pressure switch is only $25 so easy change but is it worth messing with? Running 5W-20 synthetic blend. Should I use a heavier weight to prolong the inevitable or is it just time to send it down the road? I don't want to mess with an overhaul or changing the oil pump.
It is my parts and fluids getter for the tractor, so kind of related.
Thanks in advance.
Thad
Thanks in advance.
Thad
