One more piece
SVcummins
In the books . Another 30 acres to go with the 4020 and 642 and possibly 25 more for the 3020 and 314 then about a 2 acres to power harrow and the fall tillage season which started in August will done until spring
Nice pictures SV, thank you for sharing!
Couldn't help but notice the lack of over center binders and chains on the trailer :lol: :lol:
(I had to LOL)
Carl
Great job, I have not been on here much???, but do you have a yellow dodge dually? Or am I thinking of some other guy? Sorry, I remember the truck but not the name.
WoW! Thanks for the pictures SV. I hope you can "get it all done soon" I like watching you from Georgia. Dsmythe
did you get the frame drilled and the bottoms repositioned,or did you simply remove the third bottom on the 314?
Just pulled the 3rd off I found a parts plow so I?m going to put a new trip beam on to replace the bent one and make it a 3 again
Erosion isn?t a problem here as it?s so dry and if we
get an inch of rain in ten days that?s a BIg storm for
this area
SV, you DO realize that every furrow you plow, moves the dirt down the hill 14" don't you??? 4 years of plowing down hill moves the dirt down the slope 56" plus you have a big ridge at the bottom edge of the field.
if you turned the furrows up the hill, your secondary tillage passes will move the dirt back where it was before plowing.
Loren
I just finished plowing a field that was plowed for a lot of years with a one way plow or a one way disk plow because you can see the ridges of dirt left from always throwing the dirt one way .
