A few days ago, I put some gas in the tractor and then it needed to have the choke out to keep it running. I knew that I should have drained the gas out, but I was busy. Yesterday it did not start. I pulled the carb drain plug and only got a bowl worth of gas out of it. I put some HEET in it. But I think that the only way to fix this is to remove, drain, and clean the sediment bulb. I seem to always have a problem getting the bulb to seal properly. I have some cork gasket material. Should I attempt to remove the old gasket and make a new one? I don't think the local car part places will have a replacement gasket.
thank you
SDE
thank you
SDE
