(quoted from post at 20:30:04 10/31/18) As I said you should be using a Deep V subsoiler to accomplish your goals. You are not doing that soil any good with your current program. Go to the Ag-phd site and see what the experts have to say about soil health.
Loren
(quoted from post at 16:25:10 10/31/18) The gauge wheel does more besides control depth these ih plows tend to want roll out of the furrow without it then the moldboard doesn?t move the furrow slice all the way it helps make it do what it?s doung here
(quoted from post at 12:58:48 10/31/18) My old JD LA and mounted plow did a fine job of turning sod over when I plowed an area to remove the topsoil where the double wide was going to go. I was impressed with how well it did.
IIRC the late Pat Browning said a plow (old ones) was only designed to go as deep as 1/2 the width of cut.
So you are likely going way deeper than yours were designed to go. So a say 14" plow was really designed to go 7" deep.
