Breaking the lone prairie
SVcummins
40 acres of rocks and sage brush to break out before winter and hopefully disc . Broke the gauge wheel trying to straighten it but got it welded back together how do I finish the weld so it doesn’t look like this all the time ? Bent the trip beam on the front bottom so I swapped it with the 3rd bottom and dropped the 3rd bottom off until I can find a used trip beam which a friend of mine has one . No pictures again
(quoted from post at 18:20:56 10/29/18) 40 acres of rocks and sage brush to break out before winter and hopefully disc . Broke the gauge wheel trying to straighten it but got it welded back together how do I finish the weld so it doesn’t look like this all the time ? Bent the trip beam on the front bottom so I swapped it with the 3rd bottom and dropped the 3rd bottom off until I can find a used trip beam which a friend of mine has one . No pictures again
Some jobs just aren't worth it. I bought 6 new hard faced shares for my Oliver roll-over plow a couple of years ago. I broke off 2 left hand points in the first 3 acres....the ones the guy had welded up himself. He told me when I bought them that he would guarantee them...I sent them back and he changed his mind...said they were no longer available. I finally talked him into 3 regular shares for replacements. Now I pick and choose my plowing jobs....
I charge for what ever parts break my last job was a
1200.00$ bill and another 1000$ for parts . And got
a 500$ bonus on top of it . The gauge wheel was
already bent tried straightening it while it was on
the plow wasn?t a good idea
One will be to the fence the other one on the other
side of the field the furrow will be against the fence
Eldon -- I know it would mean more work , but if the ground is that tough , would it have made much of a difference if you had chisel-
plowed it first , or possibly ran a sub-soiler , before hitting it with the moldboard plows .
Doc
(quoted from post at 06:19:19 10/30/18) You should not have thrown that dirt up against the fence. You can never get it back.
I agree. Throwing dirt too close....nothing to be gained with that. But I do not know about hitting rocks, we had none on our Iowa farm.
LA in WI
It?s not going anywhere and the fence won?t tip over either . Plowing 10 inches deep and the posts are buried 2 feet deep you do the math and a plow moves a lot more dirt than any other piece of equipment does i Hebrew completely buried a five gallon bucket standing up running only 10 inches deep I?ve dug up things with a plow that no other implement would like a chisel plow even if the chisel was working deeper depth
If it?s that rocky and your plow isn?t trip protected then it?s cheaper to and better to just chisel it 2 passes with a chisel costs the same as one with a mold board . If we start having to much trouble this will be chiseled. I?ve made grass seedbed with the John Deere chisel 4 passes the last two passes with a double spike tooth harrow behind .
Looking at your weld picture, you would be better to reverse your travel just a bit when you get to the end of the weld. You might want to slow your travel speed down just a bit, you're close but the finished bead should look like a stack of dimes laying down. Darned good looking weld there. Since you have finished, just start at the edge and fill the crater, won't hurt anything, then you can grind it off or leave it if it doesn't create a problem. Just my thoughts, Keith
finally got a pretty good half day of plowing in
