I worked on fuel valves and electronic governors for natural gas engines this week. It really helped that I did the fuel injection on the MH a few years ago, and worked with the vendor on the fuel injection in MN last year on the natural gas engines.
The fuel valve is locked at a certain position during cranking, much like duration on an injector. You pick a small position, and keep raising that position until it fires. On the natural gas engines you have to purge the engine out between attempts so you do not leave all that gas in the manifolds and cylinder, so it does take a while. You then ramp the fuel valve open until it idles at the right RPM, then allow the governor to take over once it is warmed up and can go online. The compressor is open to the discharge and has a bypass valve so it stays full, the inlet valve is opened while the bypass valve is closed to load the compressor.
It took about a day of trials to get the first engine running, then we knew where to put the settings.
These do not have temperature compensation, so I might need to go back this winter and open up these settings for cold weather.
