wire diagram
1948jr
Can someone give a simple wiring diagram for 3 wire alt. on a 265 massey diesel.From alt, to oil pressure gauge ,amp gauge, and fuel gauge. thanks
This diagram indicates Farmall, but it applies to most tractors with an amp gauge. If no amp gauge, just attaching it from the fuse link to the starter Battery connection will do fine. Use either a 2 terminal oil pressure switch (on at 5 psi or so), or a momentary contact single pole push button or toggle. Jim
