They Found The Inter Tube Hole
Dick L
The tire shop found the hole and patched it and I got it in last evening. I didn't get much sleep last night but it is in. I am not very savy about this video camera thing. I thought the screen setting were for when the camera was idle. Guess not? I reset it so will have to do another to see if that is why it only runs for a few minutes and cuts off and then restarts. When I removed the video from the camera to the computer it was seven short videos.
Here Is One
great video,,,thanks!!!What do you use the farmall for?Raking hay? Show us more pictures of all your tractors whenever you get a chance..would like to see them all.
The Farmall C is my goto utility tractor. I pull a disc, two wheel trailer, bale a few bales of hay, pull out small shrubs.
I just bought a used tractor and the bias 4 ply, tube type tire has been mounted and used for several years at least......this is an important part of this answer.....opinion. Had a slow leak. Was operated in areas where things like Mesquite and Black Locust trees were common. Was used primarily for brush/bush/grass hogging.
Did the soap and water thing and accidentally found a thorn stuck in the sidewall half way between the tread and rim. Did the plug thing in the normal manner not realizing at the time it was TT. It's been several weeks now, the tractor has been worked pretty hard and the patch is holding.
I figue it worked because the tube had time to semi-vulcanize itself to the tire and where wasn't any squirming between the two and it held.
Am still amazed.
