dangerous???
I have a couple of small flat objects in the gas tank of a Farmall M. I'm not sure what they would be, they appear thin and about the size of a dime or a penny, but roughly shaped. Would it be dangerous to drain the gas tank and go after them with a shop vac? The problem is that most of the time they don't bother anything but occasionally one gets situated over the gas line intake and shuts off the engine. Thanks, Ellis
Keep the shop vac away from the gas tank.Sucking the fumes through an electric motor will scare the crap out of you,and send pieces of the vac all around.There is a vacuum made for that purpose,for spill cleanups and such,but not too many people own one.The round things are probably old cap seals from fuel treatments,dry gas cans,etc.
No, don't use a shop vac! Recently in the news someone had spilled some gas and was using a wet/dry shop vac to clean it up, when the right mixture got to the sparks at the motor brushes it all blew and burned the individuals badly. I don't think all shop vacs pass the vacuum air through the motor but some do, it has to be cooled by something. If a magnet won't work try something sticky on the end of a stick, even real heavy grease should work.
Here's a pic of mechanical fingers. Go get some at Oreillys or your favorite auto parts dealer.
I recently had the exact same issue with my M, the objects turned out to be those tin sealing flaps that come on the top of a bottle of Heet or gas additive. I used the grabby fingers for the large pieces. I then got a siphon hose going and with a flashlight I was able to use the siphon as a vacuum and got all the little pieces and sediment. I didn't drain the gas and haven't had a problem since.
You don't want to do that unless you blow air into the tank for a couple days and completely dry it out. By sending the vacuum hose into the tank you would be drawing gas fumes to the vacuum motor which creates a spark. For what you are doing I would be inclined to reach a grabber in there if it's somewhere you can see it. You might just be able to shake it out.
(quoted from post at 09:44:19 10/18/18) I have a couple of small flat objects in the gas tank of a Farmall M. I'm not sure what they would be, they appear thin and about the size of a dime or a penny, but roughly shaped. Would it be dangerous to drain the gas tank and go after them with a shop vac? The problem is that most of the time they don't bother anything but occasionally one gets situated over the gas line intake and shuts off the engine. Thanks, Ellis
If you do make sure someone makes a video.
I put a short stand pipe in all my farmall bowl assemblies and screw them back into the tank, cures a whole lot of problems.
Hello Ellis Kinney,
If it is iron washer a magnet should do the trick. Otherwise a two faced tape, Or even a piece of duct tape is all you need. Just stick it in a piece of pipe or wood and fish them out. Even black electrical tape with the sticky part in the tip would get them out. No need to over think here!
Guido.
I have put the balls out of ballbearings in the bottom of tanks to knock off the rust. Were too large to get hung up anywhere.
Several decades ago, the Fall fund raiser for the Chicago Corvair Car Club was a vacuum cleaner contest. Each vacuum in turn was set over an open pan of gasoline and turned on until it quit running in front of a cheering crowd. The vacuum that ran the longest time was the winner. Canister units like Shop Vacs usually exploded off the canister and quit. Some uprights managed to shoot out a jet of flame out the exhaust for several minutes. Eventually they would all catch fire or explode.
After a few mishaps the club had trouble finding insurance, discontinued the event and took down their videos.
If you want to vacuum from a fuel tank, you cannot use anything with an electric motor. There are siphons which work using compressed air blowing through a tube to create suction. We used them for cleaning up debris from the various mills in the shop where I worked.
Essentially they are a Y shaped pipe. The foot is the ejection point, one arm is for the air supply and the other is the vacuum tube.
Several years ago, when I had the tire shop and a couple of thousand scrap tires out back, I found a air operated nnalert that I used to suck the water out ta those tires. It was less than $20.00 at the time. Worked very well.
They are probably the tops used to seal bottles of chemicals. I've run into them in gas tanks too, and they are a royal PITA for the very reason you state, they will get sucked over the fuel line from the tank, and cut off the flow.
The way I have gotten them out is to use an air powered siphon. Hook the siphon hose to a rod of some kind to stiffen it up. With the siphon blowing the gas in a safe direction, and into a container if possible, slowly lower the vacuum tube to the piece and hold it there until it gets a suction on it great enough to pick it up. I works like a charm, and you don't have to worry as much about it trying to move away from you, as you do with mechanical fingers (been there, had that problem too)
Or if you can't see spending $50.00 to do it you could use a $3.99 transfer siphon from your local hardware store. I have one that hangs near the door of my shop that I use all the time for fueling my tractors.
We had a food disk, probably from a bottle of gas dry in the tank on a 1550 Oliver. Was there when we bought it, but after it cut off on my brother, it had to go! He sharpened a point on a length of copper wire, stab it through the center, slapped the cap back on, and went back to work. Longest part of the whole process was finding the right piece of wire!
We had a foil like disk, probably from a bottle of gas dry, in the tank on a 1550 Oliver. Was there when we bought it, but after it cut off on my brother, it had to go! He sharpened a point on a length of copper wire, stabbed it through the center, slapped the cap back on, and went back to work. Longest part of the whole process was finding the right piece of wire!
