Apparently they made a 9 inch wide and a 10 inch wide rear for Farmall Super A, 100, 130, and 140 tractors. Had a guy stop by needing a rear rim for a Farmall 130 and I got him fixed up with an extra (had a bad tire mounted) I had. He called complaining that the rim I gave him was 1 inch wider than the old one and that made the tire sit lower on that side.
Question.....will that cause it to sit lower? Another question.....I have A few other rear rim's that have bad tires mounted on them. Is there a way to measure the size of the ram without having to take the tire off? What actual dimension are they referring to?
