F600 heater core
notjustair
I need a new heater core for the Ford F600. It?s a 1964. I assume it?s the same one used in the pickup, but I can?t even find one for a 64 pickup. Checked LMC, Dennis Carpenter, did a generic internet search, etc. They will go to 1965, but not 1864. Does anyone have an idea for getting a new one? I hate dealing with eBay but I might have to resort to it.
Did the cab STYLE change from '65 to '65? If the cab didn't change the core probably didn't either. If your local Ford dealer was in business then see if they can get you a part number from an old book and search by number rather that description.
I'm pretty sure that the F series style of cab was the same all the way from the F100 up through the F800. I can't imagine there would be much difference between the '61 through the '66 other than maybe the location of the heater hose connections.
There used to be a difference in core according to parts between recurlating and fresh air. Cab stayed same as 64-66 in 600 and larger. Check ford truck enthuist site for discussion on heater core in archives.
The cab isn?t markedly different, but the holes through the firewall for the lines are much different.
