(quoted from post at 11:58:39 10/14/18)
(quoted from post at 07:53:48 10/14/18)
(quoted from post at 09:50:21 10/13/18)
(quoted from post at 21:55:33 10/12/18)
(quoted from post at 22:42:53 10/12/18)
(quoted from post at 21:16:44 10/11/18) Plenty of stations here sell non ethanol gas,5% more reason to keep on using it.
Non-ethanol gas is not available around here at all...unless you want to pay 6.999/gallon for racing gas. Never had a fuel problem with E-10 either.
t isn't rocket science folks! There is no problem in using ethanol in equipment designed for it. BUT, for all else it is a bad, bad, problem! Even before we had ethanol laced fuel in the US, GM, Ford, Chrysler had different designed fuel components for cars exported to South American countries using ethanol laced fuels. People continuing this argument are either ignorant of the facts or just like to flap their jaws! The crap is bad for equivalent that was not designed for it...........that is the bottom line.
Pretty sure that my 1940 Farmall H was not designed for ethanol, OR the 1971 Ford 1/2 ton that I used to own, but apparently no one bothered to tell either of those vehicles that ethanol was a no-no. I use ethanol blended fuel in everything I own. Never experienced any rotted fuel lines or anything else.
As I said above, it's never been a huge problem with autos. It's more in small engines and 2 strokes.
2 stroke engines such as those in Yamaha dirt bikes? Or Stihl chainsaws? 4 stroke engines such as the 3 1/2 horsepower Briggs and Strattons? Or 8 horse Briggs? I guess all of those that I own or have owned should have just gone to the junk pile many years ago. Instead, they just kept right on running.
Then you probably have different blends where you live than we do. It would never occur to me to think you're lying or that you're some sort of freakin' retarded moron that wouldn't recognize that his engine isn't running right or notice fuel lines turning to mush. However, the opposite doesn't appear to be true. I assure you that people do have problems with 2 strokes and small engines that are directly related to the use of ethanol fuels. If older fuel is used or if the fuel is not drianed from the tank and run out of the carb, then the risk of problems increase. And that just with E10 gas. Anything more than that is reputed to be far worse for 2 strokes. If you don't believe me, perhaps you'll believe Stihl. Of course they may all be brain dead morons like me too I suppose.
Not all gasoline is the same. Knowing a few facts about your fuel can keep the engines in your STIHL equipment running strong.
What you need to know about Ethanol:
Much of the gasoline sold throughout the United States contains ethanol. [b:70195e9a12]The maximum ethanol content allowed by law for use in outdoor power equipment is limited to 10% (E10). [/b:70195e9a12]Make sure the gasoline you purchase for your outdoor power equipment contains no more than 10% ethanol. If the filling station pump is not labeled with the ethanol content, ask the station attendant what percentage of ethanol is in the gasoline.
Ethanol can dissolve varnish and gum deposits that have previously formed inside fuel storage cans or the equipment's engine. When these deposits become dislodged, they can mix with the fuel and [b:70195e9a12]plug small openings and filters within the fuel system.[/b:70195e9a12]
Ethanol attracts and mixes with moisture in the air, [b:70195e9a12]causing corrosion to metal components in the fuel system[/b:70195e9a12]. If enough water is absorbed, the ethanol and water will settle out of the gasoline blend and settle to the bottom of the equipment's tank. The layer of gasoline left floating on top has a lower octane level than the original ethanol gasoline blend, which can result in unstable engine operation, power loss and[b:70195e9a12] major engine failures.[/b:70195e9a12]
Since the fuel is often drawn from the bottom of the fuel tank, [b:70195e9a12]the engine is drawing in a mixture of ethanol and water with no gasoline and no lubricating oil. [/b:70195e9a12]This ethanol/water mix is thicker than gasoline and cannot easily pass through the fuel system. This can result in hard starting, unsafe high idle speeds, stalling, [b:70195e9a12]and can ultimately lead to engine damage or fuel system failure.
[/b:70195e9a12]
Guidelines for using E10 gasoline in STIHL power equipment:
If the proper precautions are taken, gasoline containing a 10% quantity of ethanol can safely be used in your STIHL products.
Use a minimum of 89 octane gasoline and always use fresh fuel. [b:70195e9a12]Only buy enough gasoline that you can easily use up within a two-month period[/b:70195e9a12] or use a specially formulated fuel mixture like STIHL MotoMix® Premixed Fuel. STIHL MotoMix® is a high-grade, high-octane, ethanol-free premixed fuel containing STIHL HP Ultra synthetic oil. It is a pure and stable fuel mixture that can be stored for up to two years in the original container and is ideal for machines that are used infrequently.
For air-cooled, two-cycle engines, use a quality mix oil that meets the engine manufacturer's recommendations. All STIHL oils are designed to readily mix with gasoline containing 10% ethanol.
Properly store your equipment. [b:70195e9a12]If your equipment is not going to be used for a couple of months, the remaining gasoline in the machine should be drained from the tank [/b:70195e9a12]and disposed of properly. [b:70195e9a12]To ensure that any remaining ethanol is removed from your equipment,[/b:70195e9a12] STIHL recommends adding a small amount of STIHL MotoMix® Premixed Fuel to the tank and running the engine for a few minutes to circulate the fuel through the carburetor.
Equipment should be serviced regularly by your STIHL Dealer. Items such as fuel filters, fuel lines, carburetor diaphragms and spark plugs should be checked and replaced if necessary as part of a normal engine tune-up.
