Nimco Loader Valve
Bustedbudget
New User
Hello!
I've go a two spool Nimco valve on a Massey 285 that I need to rebuild. How do I identify this valve? I can't find a model number anywhere? Any idea on where I can get parts at?
Any help would be much appreciatedQ
Do your homework..... Some of those valves are not rebuildable. Or the 'rebuild' could cost more than a new valve.Do you have a hydraulic(rebuilding) shop close by.That is the first place to check.Or you could tear it apart your self and see if there are 'blown' o rings.Those are easy. If it is a close tolerance fit that is simply worn out. You're SOL.
