Powermaster loader
Our Phone System is Down!
Please use the Contact us Form
We are working to resolve the issue ASAP! Thanks for your patience!
What Ford loader fits the 841 Powermaster?
I need something to load pallets on a trailer around the shop.
Has anyone used a three point hitch fork lift?
Some of the orchards around me use the 3 point hitch forklifts. I have used one a couple times only. In my opinion, they do the job ok, but are a little slower to use as you are craning your neck to see what
you are doing. Certainly easy to mount and dismount on the tractor, and should be cheaper than buying a loader.
I have a 3point fork. works great for moveing light pallets around.Imho,an 800 is too light of a tractor to be used as a forklift.You will only be able to lift only the lightest pallettes.
A Wagoner loader is the most common loader for a Fard. They are heavy. However 6-800 will probably work.I hope you have power steering.
There have been plenty of forklifts mounted on old Fords. If they are lifting much weight they are equipped with a counter weight usually on a subframe.
