Industry #B47 or GM #909047 bearing. Note that the "B47" number has been "recyled" and can also refer to a TINY needle bearing.
Looking for an outer front wheel bearing for a 1961 C20 Chevy truck.
This is a ball-type wheel bearing and is "unobtainium" from the usual sources.
I'm NOT sure if there's a tapered roller bearing that can be "subbed", that is the case for certain old ball bearings of this style.
I would be grateful to anyone who may have a source, or information on a "sub".
Even a useable used one would be GREAT, this 'ol truck doesn't get many miles on it anymore.
I found a list of the dimensions, NOT sure if it's 100% correct, and I don't have the old one to measure.
Bearing Bore (in)--0.9065,
Bearing OD (in)--2.2503,
Bearing Width (in)--0.79,
Inner Race Bore (in)--0.9065,
Inner Race Radius (in)--0.14,
Inner Race Width (in)--0.59,
Outer Race OD (in)--2.2503,
Outer Race Width (in)--0.48
<img src = "http://oi66.tinypic.com/xlgkyv.jpg">
Second photo is of the INNER wheel bearing, a B48, the bigger brother of the B47 I'm looking for, along with the little needle bearing you get when ordering a B47 from modern sources, NOT gonna quite fit!
