notjustair
Do high beams always run both filaments in a bulb (not sealed beam - older).
I can?t find the switch I like for the 35 Chevy, but I have the lights hooked up to an on/off style that just turns on the low beams. They are really dim, so I thought I would wire the high beam wire in there, too. I don?t want to cause it to heat up or something. It has a floor dimmer switch but the wiring is long gone off it and it is too far gone to check with ohm meter.
