Junksorter
I'm working on a '26 Hupmobile 6 cylinder engine and haven't been able to locate the correct cap and rotor for it. Does anyone have a listing of Auto-lite distributor numbers that will match it to the proper rotor and cap. The distributor number is 1G117A 2F Strangely, the point set is the same as what I've seen in 50's and 60's tractors including my two Case tractors - a 430 and a 200. I'm not sure if the breaker point plate was modified to accept this style of points. The tractor rotor will not fit the top of the distributor shaft because the Hupmobile one is much smaller. Thanks for any help.
