The leak is from the plastic side tank, where the upper transmission cooler line is connected, just under the upper radiator outlet. It leaks after the thermostat opens and stops when the pressure is released from the radiator. If I drain the radiator and disassemble the fitting is there an O ring, or a gasket that may need to be replaced? Could I clean it up and add a sealant to it? My brother wants to use it and my trailer tomorrow and so I need to fix it quickly. I really would rather not take it apart and then find out that it will require buying a radiator and have it not available for him.
TY
SDE
TY
SDE
