Norden Wide Front End Bearings
PeaRidge180
New User
We have a Farmall M with a Norden wide front end. Needs new front wheel bearings but can?t see numbers on them. Can anyone help? First
part of serial # on front end is 261 but can?t read the rest. Thanks for any help.
Forget part numbers on bearings. Just get the size of the shaft/spindle and the width of the inner race. That will give enough information for the cone. The measure the hub or the O.D. of the old cup plus the width. With these numbers we/you can easily look up the bearing sizes/numbers.
Just take the old bearings to your local NAPA,etc. They can measure and match them and supply with new bearings.
1. Aftermarket wide fronts typically accepted/reused the original front wheel hubs and bearings, so there's at least a fair chance that it uses the same bearings as the original "narrow" front.
2. Unless the bearings are rusted to nothing, or burned beyond recognition there ARE numbers on them, you just need to get them CLEAN and look under good light, use a magnifying glass, if needed,
