1971 ford 4000 3 cyl diesel with a CAV injection pump HELP!!
Sanman007
New User
I have a 1971 ford 4000 3 cyl diesel tractor with a CAV injection pump and I need to remove and rebuild.
But I’m looking for clarity on timing???
The CAV pump that I have is mounted so the cover for the timing cover is on the back side and can’t be seen.
From what I have read I will need to turn tractor fly wheel until I find the 23 Deg. Mark and remove the pump carefully then turn pump over and remove the cover to see the timing mark location on the pump and take picture or mark it?
Then rebuild or replace but set the pump marks back to the same as when removed, bleed system and crank?
CAV DPA pumps on Ford applications use a scribe line on the pump flange that aligns with timing cover mark. Drive gear has three bolts, and a pin that enters a groove on the pump drive hub for correct location. No need to locate the flywheel on that type pump.
When you have the injector pump, the drive gear for the injector pump will be just sitting on the other gear inside the front cover. Just make sure no one can crank the engine over while the pump is out.
I worked and its running, Thanks for the Help,
ONE more thing i cant seem to find the Part or Part number for the
injection pump timing gear gasket that i had to remove to get to the gear that the pump was attached to??
