What are the different methods you use to clear a piston from a cylinder on a seized engine? Does it matter what kind of seizure it is (overuse/excessive RPM, lack of oil, overheat, sat idle for decades, weather exposure, etc.) as to how you approach freeing the piston? Seems there are a lot of ways to skin this cat - hydraulic pressure, burning fluids in the cylinder, soaking for weeks with fluids, simple brute force. Seems to me that a mechanical seizure (overheat, burning an engine up - I realize that it is not truly welded together) would require a different approach than a nonuse seizure. Which is the worse type of seizure, in your opinion? Do you always overbore or replace the sleeves? How often are cranks and rods ruined in these seizures?
