Cub Cadet 7273 fluid and seals
old
So we got the parts for this 7273. Have the Loctite 515. I have the transmission back together so now I need to hook up the hyd hose/pipes and fill with fluid. A lot of the hyd piping uses banjo type bolts. So are the seals on these banjo bolts special or can I use the run of the mil brass type seals that are common on most banjo bolts. Also what fluid?? Manual calls for Cub Cadet Hyd transmission oil so is that the common hy/tran or some other type of oil just for the cub cadet
Thanks
old, sure wish you were closer. that cub fluid is 21 a qurt here. i have about five qurt that someone droped off when i was away good luck. wally
