I have a Ford 3000 diesel (1966 model) tractor and have been thinking about changing out the canister oil filter set up to the spin on type. I have read that doing this reduces the oil capacity by one quart. I also read where some conversion kits purchased did not fit the tractor (they were 1/8th of an inch too big). I have the following questions:
1. Do you recommend making the change to the spin on type?
2. Does the reduced oil capacity effect the engine in any way?
3. If you do recommend the change, where is a good website to buy the correct conversion kit?
4. How do I know which oil filter to use after making the change?
I greatly appreciate any help and advice that you may give.
