Auto sequence box delete I bought this thing last fall to
replace a new Holland 855 that turned its apron chain into a
pretzel 🥨 and I could not justify spending 2500$ on a new
apron set minus the tubes which about 20 got destroyed when
the thing exploded . So I bought this old hesston 560 in non
running condition not knowing how much electrical was on
one of these things well I?ve been a quest to get the thing
running it has a self contained hydraulic system that runs
every thing on the machine the tractor supply?s power from
the pto to run the pump then there are two brains 🧠 one on
the tractor control panel and one on the baler that are
supposed to make the thing work when it was new it was
designed so all the operator had to do was drive the tractor
then when the bale reached the size you want you flipped the
auto start switch then the baler would wrap the bale open the
tail gate run the bale kicker and then close the gate all buy
itself well that no longer works so With my trusty power probe
I tested each function of the baler and found that it works fine
by powering each solenoid on the hydraulic control valve so
now I?m in the process of getting rid of both brains because
one or both is malfunctioning and I want to simplify the
operation of this baler and get rid of all future problems with
electronic garbage you have to stop to warp the bale and eject
it anyway so it?s not like it will make the thing any more
inconvenient to use having to flip a couple of switches . There
is a guy on eBay who has made a control panel to bypass all
the garbage as well but I thought i could make my own so
that?s what I am doing hope to have it running tomorrow
