If you are looking at a new loader- just about any brand of loader will have a loader to fit your tractor with the right brackets.
If you are looking at used you need to look for one that came off of a 180 unless you want to do some drilling and welding.
For example a Westerndorf Model 42 loader can fit on a IH tractor or a JD tractor with the right brackets that mount on the tractor frame.
Bottom line,if somebody tells you one make and model,you'll narrow your search to that one and pass over dozens of others that will fit with the right brackets.
