old
- Location
- Camdenton Missouri
So I was going to move Case VAC I have that needs some work. One of the rear tires had a small leak in the tube. I was airing it up and noticed the bead did not look right and I knew it was time to pull the air chuck off and step back away from it. I did not get 5 steps when the tube blew as the bead of the tire where the wires are broke. Now it has about 2 foot of broken wires sticking out the side of the tire. Had I not steps back those wire could have been a very nasty cut or worse. Bad thing is I do not have any spare tires in that size laying around. I have 5 24 inch tires on hand but no 28 inch tires on hand
