(quoted from post at 07:34:18 06/14/18) 50:1 will work just fine. However, many 50:1 engines don't like being fed 40:1 mixtures. Not enough lubrication.
(quoted from post at 07:10:19 06/14/18) Does it really matter if you use 40:1 or 50:1? I?m working on a weedeater for a friend it says 40:1. All I have around here is 50:1. I?ll probably mix up some 40:1 just curious on opinions.
(quoted from post at 07:38:36 06/14/18)(quoted from post at 07:34:18 06/14/18) 50:1 will work just fine. However, many 50:1 engines don't like being fed 40:1 mixtures. Not enough lubrication.
You have it backwards sir. 40:1 has more lubricating oil per volume and per weight than 50:1.
40oz fuel to 1 oz oil = 2.5% oil to fuel mixture
50oz fuel to 1 oz oil = 2% oil to fuel mixture
(quoted from post at 10:10:19 06/14/18) Does it really matter if you use 40:1 or 50:1? I?m working on a weedeater for a friend it says 40:1. All I have around here is 50:1. I?ll probably mix up some 40:1 just curious on opinions.
(quoted from post at 08:15:47 06/14/18)(quoted from post at 07:38:36 06/14/18)(quoted from post at 07:34:18 06/14/18) 50:1 will work just fine. However, many 50:1 engines don't like being fed 40:1 mixtures. Not enough lubrication.
Dang, you're right. ...Sure wish I could figure out which end of my brain to figure from! *lol*
Thanks Doc.
(quoted from post at 11:45:07 06/14/18)(quoted from post at 07:10:19 06/14/18) Does it really matter if you use 40:1 or 50:1? I?m working on a weedeater for a friend it says 40:1. All I have around here is 50:1. I?ll probably mix up some 40:1 just curious on opinions.
Use the 40:1 in that weedeater. Although oils have improved, and machines have become more tolerant of less oil mix, it may be an older machine that was designed for 40:1. If you use 50:1 it will work well at idle and low power but may overheat at high output.
Most of the remaining 2 stroke engines out there(except small weedeaters, blowers) use oil injection with a variable ramp mixture set by throttle. Yamaha 2 stroke jet skis set about 60:1 at idle, and gradually increase the ratio to 35:1 at full throttle where upper cylinder lubrication demands are greater. (they aren't made anymore, all 4 stroke now)
(quoted from post at 06:00:53 06/15/18) kcm, I think you're thinking not enough FUEL.
A 40:1 mixture can be too LEAN for some 2-stroke engines that are expecting 50:1. That's worse than not enough lube, a recipe for a scored cylinder and galled piston.
(quoted from post at 11:10:19 06/14/18) Does it really matter if you use 40:1 or 50:1? I?m working on a weedeater for a friend it says 40:1. All I have around here is 50:1. I?ll probably mix up some 40:1 just curious on opinions.
