Lyndon - AB
Forgive my bit of tongue in cheek humor, I couldn't resist.
(quoted from post at 17:20:30 06/01/18) Nope no overcenter type binders
(quoted from post at 18:33:03 06/01/18) Nice looking trailer. Who is it made by?
(quoted from post at 18:35:57 06/01/18) looking good lyndon, I see your pulling a precision built trailer (I love pulling mine) you don't even fell them back there, the one I have is a 14k tandem bumper pull for the skidsteer, it pulls like a dream. all your hooks and chains are inside the rub rail (got a ticket for that at the pouce coupe scales) many years ago hauling a load of drill pipe to fort nelson!! locks on all your boomers your good to go :lol: the 2 j.d.'s going to west lock?
(quoted from post at 19:00:59 06/01/18) Dot requires a dually truck to pull a tandem or 3 axle trailer.Cost me 100 bucks to find out. The gvw of the trailer is more than the truck is rated for.
(quoted from post at 18:28:15 06/01/18) I thought you needed a tantum under the truck to pull a tri axle trailer although I don't remember where I got or heard that from . Probably on this site. I also thought you had to use wire to tie your binders down, not that fancy clamp you have on them. Other than those "serious" infractions it looks like you did a good job and I'm sure that Ford is up to the task. Your braver than me as I would never post a picture of my tie down jobs even though its just about the same as you did in the pictures. Good Job
(quoted from post at 03:08:46 06/02/18) DOT want the load binder on the left side so they can be see in the mirror from drivers seat.
(quoted from post at 06:14:32 06/02/18) With a good set of mirrors you should be able see binders from both sides.
(quoted from post at 06:59:53 06/02/18)(quoted from post at 19:00:59 06/01/18) Dot requires a dually truck to pull a tandem or 3 axle trailer.Cost me 100 bucks to find out. The gvw of the trailer is more than the truck is rated for.
I pull a tandem dual trailer all over New England with an SRW. I got inspected once. The inspector checked my reg and just to be sure he checked my door sticker and the data plate on the trailer he was happy. You see 3 axle trailers pulled by SRW trucks on the road everyday.
(quoted from post at 09:42:02 06/02/18) what brand is a SRW truck. Never heard of that company?
(quoted from post at 07:44:21 06/02/18)
I just love these posts because it is so much fun to read the things that guys just make up on the spot in order to be obnoxious! Fun times! And BTW I love your truck and trailer!
(quoted from post at 11:25:30 06/02/18) Nice lookin rig!! Is your truck all stock?
(quoted from post at 15:47:28 06/02/18) I would never x chains like that as it looks to me the front could actually be lifted up relatively easy. To me the back chains must pull back and down at no more than 45 degree angle and front forwards with no more than 45 degree angle. You are way WAY to flat with your chains. I would give a warning and make you change them before moving further.
(quoted from post at 19:47:28 06/02/18) I would never x chains like that as it looks to me the front could actually be lifted up relatively easy. To me the back chains must pull back and down at no more than 45 degree angle and front forwards with no more than 45 degree angle. You are way WAY to flat with your chains. I would give a warning and make you change them before moving further.
(quoted from post at 10:30:17 06/03/18) I don't think you can find anything on angles. I cn't. What I am saying is that tractor could be turned almost all the way around with flat tied X underneath. There is no way that that tractor would stay without moving on some of the roads I drive on. Law says can NOT move forward backward or lateral. NOw I know it says nothing about up. but that tractor is not secured in my opinion. I can almost bet it can be moved without alot of force. I don't know the measurements of all the lengths of chain and width of trailer. But I would love to make a model of that and turn it and see if it would turn. as you can see the front chain would get loose if you flipped the tractor around. so lift it and turn looks very doable to me. Not saying it would fall off it just doesn't look good to me. And yes I know the DOT make up there own rules as they see fit, and the law the way it is written is left up to interpretation, and hard to understand.
(quoted from post at 16:55:05 06/03/18)
All I know is a friend got a ticketed for have a binder on the wrong side.
(quoted from post at 14:30:17 06/03/18) I don't think you can find anything on angles. I cn't. What I am saying is that tractor could be turned almost all the way around with flat tied X underneath. There is no way that that tractor would stay without moving on some of the roads I drive on. Law says can NOT move forward backward or lateral. NOw I know it says nothing about up. but that tractor is not secured in my opinion. I can almost bet it can be moved without alot of force. I don't know the measurements of all the lengths of chain and width of trailer. But I would love to make a model of that and turn it and see if it would turn. as you can see the front chain would get loose if you flipped the tractor around. so lift it and turn looks very doable to me. Not saying it would fall off it just doesn't look good to me. And yes I know the DOT make up there own rules as they see fit, and the law the way it is written is left up to interpretation, and hard to understand.
You are welcome. I've been following the post for a few days and couldn't quite get it to paper either. Those were the 4th attempt. If it was done to scale and actual measurements plugged in then can you prove it to be correct easily. I was lucky to just find the compass and straight edge still in a desk drawer.(quoted from post at 11:33:32 06/04/18) Grandpa's Fords, thank you for the drawing and the math, that's what I had in mind but couldn't put to paper. I think it would be fun to lift the whole trailer via the tractors as an experiment, too bad a crane the right size is too pricey to rent. The model A was held down with four 5/16 schedule 70 chains, and the model R was held down with four 3/8 schedule 70 chains. I also place a great deal of faith in the rubs rails, this is an extremely well built trailer. I'm sure nothing would shift or break if lifted.
As a side note, several people have commented about the angle of my chains. Even when chaining outward from a tractor, I still do a cross pattern with a fairly flat angle. The reason for that is it allows anchor point of each chain to be as close to the outside of the machine as possible, for greater stability, and allows for a completely straight chain with no interference from tires or other obstructions.
(quoted from post at 08:28:06 06/04/18) The DRW truck requirement for tandem dually or triaxle trailers is a state thing, not a Federal rule.
Someone else reported getting a ticket for towing a tandem dually trailer with an SRW truck some years ago. Not sure if it was this site or a different one I was participating in. Something about the axle rating on the truck had to match or exceed the individual axle rating on the trailer...
(quoted from post at 09:27:31 06/04/18)(quoted from post at 08:28:06 06/04/18) The DRW truck requirement for tandem dually or triaxle trailers is a state thing, not a Federal rule.
Barnyard, yes I think that it was in the Ioloveni district in the country Moldova next to Ukraine.
(quoted from post at 10:23:00 06/04/18)(quoted from post at 09:27:31 06/04/18)(quoted from post at 08:28:06 06/04/18) The DRW truck requirement for tandem dually or triaxle trailers is a state thing, not a Federal rule.
I was thinking more along the lines of Iowa because they're just about the worst when it comes to inane DOT rules that go above and beyond Federal standards.
Yes, I'm aware you've probably driven through wherever this is with a SRW truck towing a tandem dually or triaxle trailer and the fuzz didn't jump out of the bushes, drag you out of the truck, and stand on your neck with a gun pointed at your head. All that means is you didn't get caught, or anyone that did see you either wasn't thinking of that particular rule out of the 1000's they have to keep straight when they saw you, or they saw you and decided to let you go because it was a nice day and they were in a good mood.
(quoted from post at 08:54:04 06/05/18) You want to know what DOT cops look for as far as pulling you over? First thing is "Is it a CMV?" because if it isn't, why bother?
(quoted from post at 11:10:26 06/05/18)(quoted from post at 08:54:04 06/05/18) You want to know what DOT cops look for as far as pulling you over? First thing is "Is it a CMV?" because if it isn't, why bother?
Please clarify...............
or What do you mean by this?
Is it a Commercial Motor vehicle-
[b:8764a58ef5]IOW, if it isn't a CMV then there's no reason to even look at it if you're a DOT cop looking for a vehicle to check under the FMCSR[/b:8764a58ef5]. That doesn't mean State laws don't apply if the DOT officer is also local LE. I'm just referring to what we looked for in the DOT line.
what is mean when you say "overcenter binders"(quoted from post at 17:20:30 06/01/18) Nope no overcenter type binders
(quoted from post at 12:13:18 06/06/18)Is it a Commercial Motor vehicle-
[b:4e5333c646]IOW, if it isn't a CMV then there's no reason to even look at it if you're a DOT cop looking for a vehicle to check under the FMCSR[/b:4e5333c646]. That doesn't mean State laws don't apply if the DOT officer is also local LE. I'm just referring to what we looked for in the DOT line.
As I thought, your concentrating only on CMV's because that is where your agency can reap the biggest fines?
Does that also mean DOT officers are purposely ignoring privately owned, non-commercial vehicles when they see an obvious problem?
And I thought after 911, Homeland Security made it so that all LEO agencies are authorized to enforce all laws of the land.
Game Wardens now pulling over vehicles for a burned out tail light, etc.
(quoted from post at 12:35:30 06/06/18)what is mean when you say "overcenter binders"(quoted from post at 17:20:30 06/01/18) Nope no overcenter type binders
The point Barnyard, is that the FMCSA regulations are SIMPLE. They just don't care about all of the little details that YTDT gets so much fun out of. Does the truck have the legal load capacity to tow the trailer or not? Simple! The inspector checked the truck and trailer data plates. Simple!
(quoted from post at 06:21:55 06/07/18)The point Barnyard, is that the FMCSA regulations are SIMPLE. They just don't care about all of the little details that YTDT gets so much fun out of. Does the truck have the legal load capacity to tow the trailer or not? Simple! The inspector checked the truck and trailer data plates. Simple!
Then why do we hear horror stories of truckers being fined heavily and put OOS because some empty holes in the frame of their truck were not filled with bolts? If they're not looking at the little details, such things would not happen.
The way you talk, I should be able to park my skidsteer on my trailer with no chains or straps and head on down the road. Truck and trailer have the load capacity, so what's the problem? They don't look at the little details right? Baloney! The right DOT officer is going to put me OOS because I used two chains instead of four, one on each corner. The next is going to put me OOS because I used a strap on the bucket and not a chain. You just never know what the DOT officer is going to nit-pick on any given day. You can do things a perfectly valid and safe way for decades, and all of a sudden one day a DOT officer will tell you you're doing it wrong, write a ticket, and put you OOS. I read first-hand accounts of this ALL THE TIME.
So your assertion that DOT isn't looking at the details is bogus.
Simple, barnyard, you hear stories because stories are interesting to tell and to hear, and the more they are told the more embellished they get, right? So far as reading first hand accounts, how do you get the inspectors to email their summonses to you? are you really a DOT administrator posing as a YTer?
(quoted from post at 16:39:41 06/07/18)Simple, barnyard, you hear stories because stories are interesting to tell and to hear, and the more they are told the more embellished they get, right? So far as reading first hand accounts, how do you get the inspectors to email their summonses to you? are you really a DOT administrator posing as a YTer?
So the only "valid" firsthand accounts are the summonses written by the DOT officials? "I personally was written a ticket for XYZ..." from the trucker that ACTUALLY received the ticket carries no merit? They're lying, making up stories? Wow. I can see continuing this discussion further would be a complete waste of time.
